replacing water pump
Silly question does the timing belt need to be removed to replace the waterpump and other ancilary belts? just the timing belt was replace very recently and I'd rather not mess with it if I dont have too!! :D
Also is courtesy the best place for waterpump and belts?
But, if they werent done with the cambelt, you should replace the thermostat and the two top water hoses, while all the bits are off. :)
Im sure the pump comes off with the belt still on too
Yep belt can stay on :) DEFFO replace the 2 water hoses behind the upper rad pipe at the very minimum!!! Thermostat is so cheap to replace you may as well do it anyway.
Who did your cambelt?
The normal consensus here is to replace the waterpump, thermostat, 2 stupid little water hoses and remaining drive belts with the cambelt change as these all need to come off anyway to do the belt.
I didn't know this at the time either and sure enough, a month after a new cambelt my water pump went and one of those stubby hoses sprang a leak :o
Richard :headvswal
Water Pump is $85 ea
Thermostat is $9 ea
Bypass Water hoses: $4 ea
just ad this reply from concept z
sorry forgot to ask for belt as i just got a new pully and belts coming
