Seat belt
My drivers belt, has decided today, that it no longers wants to reel back inside the door, but is quite happy to flop around like a limp thing...
Is this a comman fault, i'm guessing i'll need a new seat belt unit, is it easy to fit ? and does anyone have one they would like to sell ?
cheers guys
Mine failed a safety check with a notch worn into it where it exits the door panel.Its pretty easy to replace once you remove all the screws holding the door panel.Surprisingly cheap as well,I paid about $56 (23 quids).There is a write up on removing the door panel,on the USA Z site I think.
cheers guys
hi mate try andyz in the traders section he should have a second hand one
yes this is a common fault mine arnt that good springs are weak in the mechanism
greg
Cheers guys, i knew i'd put a little weight on over xmas, but not enough to bust my seat belt lol
I've got two Jap ones for sale which both fully retract fine.. Will do you the driv one for £50.
If your zed is a UK one it wont fit.
Edit: Yeah easy to remove/replace - door card off then a couple of big bolts :)
Pete
