No Power from Cold Start
I have a 1994 N/A Auto 55,000miles.
In this cold weather she will start first time but then if a little throttle is not applied the engin just dies and seems to flood, as the only way to restart is foot flat on the floor and keep on winding. also there is no power to pull away until the engin is warm (when the temp guage comes up) again the engin will just die :headvswal
service 3K ago new plugs etc and whilst I was at Billing had the Dutch boys put their tester on, every thing fine exept for occasional miss fire on one cylinder.
Help please :bow:
Steve
id start by making sure the temp sensor is ok along with the connector/harness
Try checking the conectors on temp sensors, idle speed is set prop , Tps is clean and ok( the conectors this is) if it only fires on 5 also make sure all your coil pack conectors are ok too.
Hope this helps bud ;) if not someone will be along shortly to put you right.
Yep I would say its the temp sensors too.
