Manual Gearbox Question
When I'm in 3rd gear, my gearstick moves backwards when I'm accelerating and forwards when i'm not, the movement is only about 3 mm but it is noticable, any idea's as to the cause ? I hope this doesn't mean the gearbox is on the way out!
Herman
no no big issue there, from what i understand there is a little bearing underneath the shifter which needs replacing, it is about 4 squid and you have to remove all the interior above the shifter then change it and presto
I have also posted about my gearbox being noisy in 2nd and 4th, more so 2nd, it was suggested that it was a 'top geabox seal' being split. Could this also be replaced at the same time ?
ThankZ
Herman
that will sort that noise otu aswell, the rubber around the gearbox may be loose and can be sealed at the same time.
reall nothing to much to owrry about i think.
Any Idea what the part numbers are ?
Herman
