protoj · 18 hours ago 18 hr
Sorry its such short notice but I had a call from a friend asking if i was going to the jap car meet in Bolney West Sussex. Any of you guys going or has know one herd about it. My m8 said it should be good and its not far from Dorking if any one is interested.
Tim
