how far is the clutch pedal meant to go down before you can feel some proper resistance as my pedal goes almost half way down before you can feel it doin anything????
im wondering if threre is air in the system or it has a fualt there is no noticable fluid loss and the clutch opperates ok but it bites very low to the carpet any ideas ??? :(
yep there is a servo on the system to help you press it in.
the peddle shoyld feel hard before you start the car> place your foot on the peddle
feel it hard, start the engine and you will feel the servo make it lighter.
this is normal.
sometimes the servo unit leaks pressure and pushes the master cylinder in and depresses the clutch so giving clutch slip. this happend to mine and the part is $450.00 from the US. but its a bitch to fit so i relaced both master cylinder and
clutch booster servo. Neat job done! also you can get air in the system and it needs
bleeding at the clutch bleed nipple on the d/side wing (under bonnet) and the slave
cylinder.
hope this helps and it ent the booster
allan
just tried out the booster pumed pedal to empty servo just like your brakes pedal went hard then fired her up and pedal got lighter so its working thank fck. but the pedal doesnt go half way down i was exagerating it goes about an inch inch n half before it does anyting is this normal as im used to cable opperated clutch ??
