UK - Wiring Diagram that shows heated seats
Hi Guys
Still trying to find out how to wire up UK heated seats in Jap Spec. I have the seats the switch and the time delay relays...loads of short wires....but no loom :eek:
Does anyone have access to a UK wiring diagram showing heated seats? The Service CD I have just shows electric seats.
Martin
:dance: Get a pro to do it :duffer: You don't want to burn your bum :dance:
i think AndyP has the suplimentary wiring diagrams?
Martin
...when I got a set of heated UK spec seats for my NA, and pulled everthing apart, you'll find the wiring loom is completely different. I tried as best I could to incorporate the switch and all of the wires that came out of the UK TT, but it appeared impossible. Simple solution was to wire up a pair of switches on the dash from a live feed (ignition on) to the seats. It works ok, you just have to remember to switch of the seats - not a problem as they get pretty hot...
Good luck
Jack
Martin
Good luck
Jack
OR
Put in a couple of temperature switches, like mini thermostats that will switch them off at a predetermined temperature !
Olly.
Toasted Botties anyone. :D :D :D
