Idle
Is this what you guys call rough idle?
Car once warmed is idling at very low revs. This has only started happening over the last two or so days. Its lowest is 450 and then the ecu seems to try and up the revs and so a bit at a time the revs get up to 900 but then shoots straight down again.
Hope ive explained this ok, all help as always appriciated.
Martin
[This message has been edited by martinfa (edited 02-11-2001).]
Hi Martin
Check out Maceij's ( aka Z Viking )web site. He has a tech section with a step by step guide on what to check to sort the idle. It helped me a great deal when I had this problem.
Seez ya!
Simon H
Hi Simon
Thanks for the info, could you remind me of the URL please.
One day yourself, Glen (senna), T3RBO and me must have a mini south coast meet.
No probs M8, www.z-car.net is the site you are after. Good idea about the far south Zed meet. I will see if Glen is up for it, anyone else way down south up for it???
Seez ya!
Simon H
Which bit of the south coast are we talking about?, i.e.Hastings/Brighton or Torquay/Portsmouth?
With regard to the erratic idle I had a similar problem but upwards between 1000 & 1500 rpm. I did all the usual stuff but to no avail, I eventually found that the connector block near the Throttle Sensor gizmo needs to be pushed together REALLY hard to get a good connection, then the problem disappeared. I hope this helps.
Laterz,
Jonezey.
Coming from the IOW I am bound to say Portsmouth Jonezy. But I would be happy with any one of these venues for a mini Zed meet.
Thanks Guys.
Where are you Jonezy?
Bournemouth is ok with me Martin. Just need to hop across on the Yarmouth to Lymington ferry then 20mins down the road. Lets see how many other south coast Zed onwners are interested.
