Engine oil drain valve..
What a neat little invention: http://www.fumotovalve.com
No more getting covered in oil (well, ok, it's not that bad, I know) and no more buying sump plug gaskets..
Very tempted to get one of those..
(Apgologies if it's been posted before - I did try a search on 'fumoto' and 'fumoto*' etc)
Are you gonna order 1 matey as I am deffo interested as well, will make life so much easier and probably mean I would change me oil more often !!!
If you find out the right size that we need and are ordering then I will have 1 too.
Olly.
I'm not sure yet - I would like one.. but I'm also penniless, which is a slight problem :rofl:
FYI though, the right size seems to be the F103, or F103N if you want it with a 'nipple' (fnar fnar) for attaching a bit of hose to.
I reserve judgement.
I would like to see how easy it is to unlock the valve. Like is it possible that road debris could hit it and unlock it?
well your still going to get covered in oil taking the oil filter off
hehehehe :D
just what i was thinking
You'd struggle with one of those on a Z - the sump plug is low enough as it is, never mind protuding further down - helloooo speed bumps, bye bye oil :D;)
