My heater goes hot and cold
Hi All,
I have the problem of when I turn heater on full, it will go hot for a few seconds and then bacl to being luke warm.
I have had the car on ConZult and that shows no errors.
Any ideas.
:rofl:
Trapped air in the water system?
Try bleeding it and toppping back up.
And to anticipate the next question, there's a bleed screw on the left of the radiator. Run engine cold for a short while with screw undone and rad cap off. Don't run it for too long, because when the water starts warming up it'll come out of the system!
Could be a restriction in the heater matrix, the heat is allowed to build up when the fan isnt blowing but wen switched on its cooling the matrix. The hot water cant flow through quick enough to keep it at the right temp, so it starts to cool. ;)
Thanks for that m8 i will the above and keep you posted if thats alright
:mac1:
