gearbox question
Hi i have 93t/t manual and when u get to the biting point on the clutch shaply , then i can feel the gearstick jerk a bit , also happens when you tap the accelarator and let it go suddenly but this is only happening when moving. Any ideas? Could it be a gearbox mount loose or worn ?? :hyper: :rofl: :bow: :duffer:
If the movement is side to side then this is the normal torque reaction of the engine, but if it's particuarly bad then it could be down to damaged engine mounts.
Having sat in karl's car last night, it's not the link bushes. As i didnt drive it, I couldnt replicate the feeling at standstill.
yep , as jock says its not at standstill only when moving and its only jerks forwards and backwards but if engine mounts then wouldnt it do at standstill too in gear??
mine did this mate may not be the same but i fitted a shortshifter with new bushings and no movement at all
