dodgy idle when cold
now them cold winter mornings are here my z hates tickin over when cold (even with the aircon on)am i right to think its a dodgy air regulator? the neighbours love me at 6 blipping the throtle :D
any ideas guys this is startin to get quite bad now had tha aircon on this morning and still had to blip it for a few mins or shed cut out.
Try checking/cleaning the ECU temp sender connector, if that don't cure it do a search on here HTH :)
Two things I'll suggest - If you have multimeter tester, you can test the MAF, can't remeber hat it should read off-hand but will check for you.
Second, don't rev the engine when warming up - especially if its a turbo Z. If not turbo, bear in mind most engine wear happen within the first few minutes of start-up.
There are so many things that can cause this problem. If you go to this site, it has a lot of good information. When you get on the site - click on the TECH part.
http://home.swipnet.se/e-solutions/
thanks ill try cleaning that n ill take a look at the site.tis a tt but i only rev it ever so slightly only way itl keep runnin never gets blipped over 1200revs
Could be poor compression
I had the same problem a while back so i removed all the pipes running to and from the induction (3 on ech side - six in all) i replaces them all with silicone jobbies and it worked fine.
Any splits in these will cause crap tickover
