Mr Duff has striped down his engine how many piston crowns do you think he has broken?
  • Replies 39
  • Views 975
How many pistons did Duffer break? 39 members have voted
  1. 1. How many pistons did Duffer break?
bugger - don't tell me he's broken his engine :shock:
Yes mate,but it was always on the cards chasing power with stock internals :x: :x: ;)
There is a video of it happening at Santa Pod
I think he broke it deliberatly cos he likes stripping his engine so much :D
Well if he likes it so much, then why did'nt he say..... He could do mine :mac1: :rofl:
C unts :D:rofl:
http://www.z32.pwp.blueyonder.co.uk/andyatpod.mp2 (for about the 20th time :D )
The correct answer is NONE :tongue: However, 3 out of 6 have completely destroyed the ring lands, with one ring being broken into 3 pieces :D So, 14.0 second standing 1/4 @ 104mph on 3 pistons (@14psi) - this is gonna get interesting me thinks ;) I'll get some piccies taken and post them up on here. Don't you just love a bit of destruction :D
Basically, the wastegate actuator hose on the drivers side split, then when the 2 lines were tee'd together for the boost controller, this effectively meant BOTH weren't connected. >26psi on stock injectors and stock ICs is very fun but not for long LMAO. Amazing thing is, apart from the ring lands the pistons are absolutely fine, which would suggest NO detonation, although one plug has shattered the insulator on the nose so something was happening in there :D
Next year @ pod is gonna be VERY interesting me thinks ;)
CheerZ,
Andy
Muffle Duff I have told you before but you just wont listen,DONT run above 19psi with those tubs :slap:
http://www.twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=1269061
I thought I would ask PE themselves if they have better actuators or have a housing that can accomadate external wastegates.
Heres the email that I recieved that I thought may interest some.
"Those turbos were not designed to exceed 1.3kgm cm/2 or 19PSi. Runing any more then this boost level completely exceeds the thermal effiency of the turbochargers meaning running increased boost pressure could cause turbo failure and the gains would be minimal per PSi. If you were to run stiffer wastegate springs the actuator mounting brackets could possibly and may already be folding. To obtain greater power it would be best to run larger turbos at the sacrifice of lower-end power but in turn they would generate more efficient air flow at higher boost levels. "
Interesting that it sounds like they expect the mounting bracket to be pritty damn weak.
Were PE talking about the turbos running on a VG30DETT though? ;) Its not just about pressure, its about FLOW as well, so lower flow (feeding 3 cylinders as opposed to 4) means higher pressure is possible within the efficiency areas :) They'll be fine :D Anyway, I wasn't running >26psi on purpose, the actuator line split so the wastegates never opened :tongue: :D ;)
Yes we are so dont try and confuse yourself bud :tongue: :rofl: ;)
Well take a looky at the flow charts for the 1420s then :p They're more than capable of running up to 2 bar ;)
And here's the pics, appologies for the size, you need to see the destruction clearly though :p :D
Niiiiiice :D
LOL I see so the email sent from PE themselves must have been from the office cleaner :rofl: :rofl: :rofl: ;)
I don't think they were talking about its application to a VG30 tbh m8 ;)
You two make such a lovely couple.. you really should tie the knot you know
oops.. forgot the ;) :D
*hides under the pile of broken pistons marked "Andy & Iains broken bits"*
LOL Its only light hearted banter mate and he knows it:D,much much tamer than the days of Timmy Wazza and Senna threatening to burn eachothers houses down and wanting eachother dead LOL :rofl:
Course m8 ;) As was my comment.. honest.. :D
Hey - don't forget me! I distinctly remembering threatening ... bugger ... you
:mac1: :nelson: :x: And Senna..
Can't remember if there was anyone else ;)
:o :o
Yeah the pills and constant electric shock treatment have finally taken their toll, can't stand the uncontrollable dribbling outta left side of mouth though! :D
:D I've already told you Mac, buy my ICs and Injectors, THEN and ONLY THEN will I swallow :rofl: :p
:D I've already told you Mac, £30 a job, and ONLY THEN will I swallow :rofl: :p
And a little birdie told me you swallowed for a fiver Andy.. I reckon you're just trying to "milk" Mac because you think he's rich ;)
:rofl:
:rofl:
Nope, Andy just likes the taste of bo11ock yoghurt! PMSL
:rofl:
:rofl:
ROFLMAO :rofl:
Shouldn't that be driveling mate :D
