fitting a Greddy turbo timer harness !!
I've just got a turbo timer harness and it says it for the z but do i just plug it in from straight out the back of the ignition barrel. Just wondering because the harness doesn't seem to fit there and i was wondering if you fitted it else where before i send it back. Cheers
[sIGPIC][/sIGPIC]
Any idea anyone ;)
[sIGPIC][/sIGPIC]
greddy harnesses are made for Jap spec motors, if you have a UK spec car they have a different connector on the back of the ignition barrel :(
Cheers mike, It's a Jap import so i should be able to just disconnect the ignition barrel connector and plug the harness on but i can't :mad: Ive had this Z for a 14 mths and have noticed there is evidence of spraying around the door handle. I wonder if a nice person of the community has borrowed it without consent and the barrel has been changed. I got the harness off a good reliable trader on here so thats why i doubt it his mistake. Anyway it says that its for my car on the box.
[sIGPIC][/sIGPIC]
i bought the one for my car off a tradder
when jd fitted it it was nothing like right
he did a bit of cutting and soldering
and bingo it worked rather him than me
steve
I'm having the same trouble as you - mine is a J-spec and the new harness is completely different (in terms of connectors) to the old one I took off.
I'm here :)
You both have the correct harness i'm puzzled as to what is going on, you have the same harness's that have been fitted to at least 30 zeds :confused:
I'm here :)
I think its a problem with nissan being inconsistant in their barrels
but having the harness makes it a LOT easier to fit the turbo timer anyway by splicing.
Follow this guide and also the wiring diagram on back of the greddy package.
http://www.300zx.co.uk/forums/showthread.php?t=29201&highlight=timer
I got a blitz dual jobby, and that fitted straight in no probs. (uk spec) :confused:
Chris,can you post a pic of the end of the loom?
Yeah will do
Cheers for the input everyone. Hope this problem will be solved soon.
[sIGPIC][/sIGPIC]
Chris buddy, as you can see,the one i recieved is different :eek: The two male pins on the socket are on the opposite side and the female socket has five prongs on it :( Never mind buddy,not your fault ;) harness.JPG
[sIGPIC][/sIGPIC]
Wierd as i had a box full of these harneses from Greddy. I'll get you one of the others out tomorrow bud :)
Cheers buddy, ill get the other back to you ;)
[sIGPIC][/sIGPIC]
Would it be possible to swap mine too?
Sure matey :) but first can you give me the number that is on the front sticker IE TT14-22
You see guys,this is one of the reasons why it is a good idea to buy from the traders on the board,If you have a problem with a part they have sent you,they are only too pleased to sort it out.
Unlike some ****ers on ebay and over the pond eh Kirbz:D:D;)
Sure - I'll get it to you when I get back from work this evening. Thanks mate :)
Decided to call at home over lunchtime - the sequence on the box is TT14-22M. Hope that helps.
  • 4 months later...
Just realised the RAZO Turbo Timer i bought some time ago had an additional set of wires with those connection on the end. DOH the fitting kit. And I just bought a blitz turbo timer. Hmmm teach me to be thick.
  • 2 years later...
