How do I know how much mine has been lowered by?
In need of help yet again.
Now this sounds like a stupid question and might well only require a stupid answer to sort it. :D
I am fitting a camber correction kit soon and I assume to get it set up right I will need to know what sorta drop my car is running.
Trouble is the car came from Japan ready lowered so don't have a clue what springs I am running therefore at a loss as to how much its been dropped.
Any idea how I can tell?
Justin
ask someone on here to measure something on a std one and compare, say bottom of front spoiler to floor ( providing both have stock or same from bumpers. Maybe door handle to floor?
Yeah, that seems like a good enough idea. Cheers Scoops.
Ok then, any one running standard ride height here?
Justin
I seem to remember that once, long ago in the dim and distant past of the forum, AndyP measured the distance between the ground and his rear spoiler, and possibly the ground and the top of the wheelarch (in order to determine that imports are slightly lower than UK cars as standard).. It might turn up with a long search - you never know :)
Thanks Aaron,
I have tracked down the post thanks to advanced search. Look like 975mm is the standard jap spec height from the top of the spoiler to the ground:)
