Help pls - problem with lights
Hi - I have a problem with my side lights - the switch is off but the lights won't turn off.
I want to remove the fuse temporarily to save my battery going flat, but the fuse diagram is in Japanese :confused: Can anyone tell me which fuse I need to remove?
Also, can you advise as to what might be causing this prob?
Thanks for any advice. Ummm, you're talking to a girlie here, so nothing too technical pls - I'm surprised I managed to find the fuse box at all :D
Thanks and sorry if I'm being dumb, but I can't see a fuse for the lights in the first link to translated fuse diagram, and I'm not sure which part of the online manual I'm meant to be looking at
I had this problem. Turned out i left my fog lights on. :)
Actually you're right - sorry for posting wrong one. There is an other fusebox under the bonnet (driver side) and also a relay box (passenger side). But I don't know exactly where the answer is: except I know it's in the manual somewhere. (failing memory = old age or living through the 70's)
Nice one Scotty - you're a hero - fog lamps were on, couldn't see them cos it's so bright here today.
Thanks for your help as always guys :)
