What else should I change at same time?
Booking my Z in for cam belt and new radiator.
It's done 60K so what else is worth changing at the same time that's not going to cost the earth?
And don't say everything!
If you are going to do the cambelt,then do the water pump as well
Possibly also thermostat and deffo new auxiliary belts. Best bet is probably to check what the 60k maint kit from courtesy contains and just do all that....
CheerZ,
Andy
For wot it's worth I can vote for the Water Pump & Thermostat. Make sure you get the two water hoses going from the heads done. The hoses are only a tenner. I'll send you a pic of what I mean if you want.
My car overheated twice, 1st with the hoses splitting and the 2nd with the rad going. My water pump went but not too bad for the car to overheat.
Now I have cracked heads to deal with.
crazyeddie.co.uk
[This message has been edited by crazy_eddie (edited 29-10-2001).]
