warning light query
1991 J-spec 300ZXTT
When I switch on/off the cruise control, no light appears on my dash...
On the right of the steering wheel is a panel which lights up for overdrive and power
on the left of the wheel the panel never seems to light up ever (not having a manual makes life hard!)
Any advice on where c/c should light and what should light on the left panel?
Robb
You're right, the pannel on the left of the wheel has space for 3 lights, from the left they should be - CC on, CC set and (I think) HICAS warning.
Hope it helps
Tim
thank you...
would it be bulbs behind panel or a fuse?
Robb
TT Tim is right mine id a 90 Jap TT auto and I have the 3 lights , 2 green C cruise sytem initialised and set ) and the Hicas ( Amber ).
If the CC is working them it probably is the Bulbs. Best of luck if you are going to change them.
