Auto Gearbox Help Please
Please Help If You Can. I Am Haveing Probs With My Auto Gearbox It Will Not Change Gear In Normal Setting But Will Change In Hold And Ore Power Also It Sits At Higher Revs About 1500 Dont Know If This Is Connected To Gearbox Trouble Ore Evry Thing Is Happening All At The Same Time Can You Help Please.
the high rev's might be the same as mine was. the yellow connector on the metal water pipe just behind the fan shroud take it off and check the it's clean and not corroded if it is, clean it off. might sort it.
