Fog lights on non-UK rear bumpers....
If you've not got the UK rear bumper what have you done for a rear foggy?
I guess converting a reversive light with a red filter is an option...
I used the inner pair of brake lights and a separate switch. Jeff has hooked up a relay so that the inner brake lights are used as fogs when switched on, but as brake lights the rest of the time.
Ditto.
Tim
Jeff,
You got a wiring diagram for that set up, had the inner brake lights converted to fogs when i bought the car but I do like the idea of a switching relay.
Thanks in advance
Tim
Now THAT is an excellent IDEA!
I MUST use it, I didn't like to lose the original setup!
And you pass the MOT no probs I assume...
Thanks guys!
Details of the correct relay would be great.
I've got a seperate light under the bumper on my jap spec but buggered if I can find a switch for it... but it did pass mot last month!!!
prefer above idea though, any more details
cheers robb
turboman
as just discussed on Hairsy' thread, my jap came with a switch that turned the right rear reverse lights on.
they was a white bulb in but managed to get red and passed MOT np.
Below my wiring diagram for the rear fogs works well and mot pass.Jeff TT
[This message has been edited by Jeff TT (edited 23-10-2001).]
Jeff,
I can't see the diag frown.gif All I get is a broken link. Any chance of you posting again?
Ta
Tim
Try this
http://www.z32.org/unsorted/Fog%20light%20wiring.bmp
Ah just thought its a bitmap I did in paint may need to redo it in another format for those without any suggestions anyone?
Jeff TT
Just re-wired mine - Thanks...
Still waiting for the relay to compelete it, meanwhile the inner stops are just fogs.
If anyone still wants details on re-wiring a UK 300 with original fog button to use the inner lights (due to new rear bumper) I'll post more details.
If you wire up the inners without a relay you may want to disabe the "brake check circuit" for the stop lights.
Cheers,
Jez.
