Parts Cat.
Does anyone know where i can find an on-line parts guide.
Need to phone the oiks at my local Nissan garage to order a part.
Unless you have the actual part no. they haven't a ****ing clue!
The two part numbers i'm after are the two relays that work off the emission,when the idling falls too low they pick it up but mine are shagged and just keep buzzing throwing the idling up and down....before you ask i've dismantled the AAC and checked and tested all the solenoids which are ok and cleaned all the valves....
Anyone?
Nissan part no's
Type in relay,lots of them, not sure which one's you require.
Nope still no good think i need a good picture of the engine bay so i can highlight what i actually need.
Hey Vijay new turbo's on their way yet????
The two parts sit just behind the set of about 7 relays in one box.
They both have about three tubes going into them and look like two little metal cylinders.
They both look identical apart from one has a white electrical connector and one is black.
Actually i'm thinking it's one of the exhaust gas sensors but i could be wrong...could this effect the idling if it's too low then try to pick it up?????
Hello mate,
Are you talking about the oblong box of fuses on the drivers side? If so are you talking about the AIV and EGR solenoids??
Vijay
Thats what I was thinking Vijay.... I had loads of these but threw them in the bin when I junked the EGR and AIVs LOL I'll have a dig around though ;)
No mate not that bit just behind,spoke to Jeff and he's sending over 3 spare ones think they are actually solenoids........working off the exhaust gases......
yeah, just behind that fuse box is the AIV and EGR solenoid valves.
Vijay
