Hi,
Quick question how does the bonnet panel above the air filter come off? I popped the bonnet & removed the 2 screws underneath but the panel still seems to be bolted at the bottom front end. How/where do i access the bolts??
Also i noticed that one of my main front light cluster units is loose when the bonnet is up. How is it secured to the car body?? I assume the previous owner has left some bolts/screws out. I had a quick look at the other side but it is as dark & cramped as an elephants armpit around that area :)
Barry
Hi,
Barry
those 2 bolts should be enough IIRC usually a bit tight but with a wiggle should free up ;)
The light are secured by 2 nuts and 2 bolts. The front corners of the lights have studs which you put a nut on, You can reach the inside front stud when you take the head light panel off. The other front one you have to take the inner wheel arch off I think. The 2 back fixing points you put a bolt through from underneath. I think you can get the outside rear fixing point from under the wheel arch, while the inside rear on is a real paint to reach. fixing it by 3 points makes it secure, but 2 points it will still wobble.
