Buzzing from footwell....
I can hear a buzzing sound from near the footwell somewhere,it is intermittant but when it does the idling shifts from 750 then shoots up to 1200 then down to 600......is there an idling relay that could be loose or have a bad connection somwhere down there????
Could be the missus' vibrator fallen out of the handbag?
Whats your mussis been doing in Alexporsche's car? :shock:
Getting some sweet mechanical love by the sounds of it :dance:
Have a word with Jeff, I'm sure he could suggest a 'fix', like ear plugs or somet :rolleyes: well you won't be able to hear it anymore, whats the problem? :D
I would suggest you take a grinder to the footwells, once you have completly removed them you should find that the sound has dissapeared.
Definately not a vibrator as i've a huge ***k she doesn't need one plus mine has 5 attachable heads....
So apart from that or a wasp caught somewhere tricky any other bright ideas????
And you can use your legs Fred Flintstone styleeeeee, bonus, should be quicker too...less weight and leg power!!
personal earthing kit instruction :hyper: :hyper: :rofl:
