Bigger injectors question
I've got a boost controller and JWT ECU.
Can bigger injectors just be plugged in or does the ECU and other bits need changing?
I assume the injectors are just pumping larger amounts of fuel at a time so more boost can be used. I'm running 16psi now so what could I go to?
How much do they cost and how easy to fit?
Are there any scrapped cars out there with suitable big injectors for my Z?
I'm Z broke anyway so not for a while anyway but I can dream.
You need to have the ECU reprogrammed ($100 at JWT).
A set of injectors (preferably Nismo) costs around 1000$.
You remove the upper intake manifold to fit them.
Maciej
And removing the upper inlet manifold is not a quick job.. Trust me, I speak from experience biggrin.gif
Az
