Installed Profec EO1 and No Boost or RPM
Trying to help a mate out, he installed a Profec E01 the other day and is having trouble boosting above 7psi and the display won't show RPM!
I had a look at some of the settings and could not see any problems!
Any Ideas
Thanks but original solenoids have been removed!
has it been wired correctly ie did he splice into the correct wire for rpm?
He insists he has unless, its has come loose, but the manual says it does not need RPm input to control boost :confused:
Check the solenoid connectors at both ends of the cable ;) Unplug and re=plug making sure they engage properly. Seen this once before on a blitz unit and thats all it was :)
mine didnt show rpm, also make sure youve selected the correct type of air flow sensor.
