Little problem
Just took all my induction pipes off - and if you look from the fron of the car - the right hand side intake has 3 rubber hoses attached
1 massive one
1 smaller one
And one tiny one
i removed them all only to get called away for an hour, and when i came back to the job - forgot where i was. The problem is, under the right throttle body there is a tube for a tiny pipe to attach to, also, ont the induction pipe there is a tube for a tiny pipe to attach to - unfortunatly i can only find one tiny pipe coming from near the air filter !!!
Is this supposed to go to the throttle body or the induction pipe ?
And is there another one about - only i cant find it anywhere !!!
The car starts and seem to run fine - but ive only had it on choke and not given it chance to idle yet - which is when i should imagine, i will get problems
Thanks for any help guys - im a bit stuck here
Errrrrrm need a better description really. Tiny pipe is for carbon canister, middle one is either recirc or actuator, and large one is erm, well the main boost hose...
Are you talking about at the throttle body or the IC pipe coming up along side the rad????
sorry for the crap description !! Im running an NA mate - so no I/C or Boost to deal with
Urgh DOH! :D Got a picture of where you're talking about then?
Sorry its the only pic ive got - my phone sent pictures to my pc hours ago - and still aint got em !!
