Seatbelt won't rewind, any solutions?
If it's stuck all the way out, you could try taking it apart and seeing if the mechanism is just jammed.
If it's just retracting really slowly, or not at all, try taking it apart and winding the spring a bit tighter.
Unfortunately, the plastic cog in mine had numerous cracks in it and had shattered, meaning I needed to get another one from AndyZ.
Cut it off.
Could it be on the electrical side?, ie; the belt retracts when you press the release button on the stalk. mabe it could be in this area?
Just a thought.
mines the same need a fix soon hopefully :( MOT time coming up! my mate does the MOT so hopfully it will be pass&advise LOL
Cut it off.
It's worth hanging onto your seat belt.
If you wear one you can drive after eight pints.
If a copper every questions this, just tell them Craig David said it was ok and you'll be on your way. ;)
maybe you should come to my house and fix my seatbelts then it will BE CAN I GET A REWIND
PMLS
I'm not really called Craig David though... but I'm sure you guys guessed that!
Apart from buying a new one?
Apart from getting a replacement,not a lot you can do bud,new or second hand?-your choice.Deffo don't advise stripping it down! HTH.
Why not? It's pretty easy and there's not a lot you can do wrong.
Mine did this. A small spring in the mechanism had come off because the plastic it was attached to had snapped. I used a match stick and some super glue to fix it and it was fine. If yours is the same then when you take a look you'll see the problem straight away.
Darren.
gain about 15 stone and it should fit fine
