Me again.
So I have two questions:
RobHowl ·
...one that isn't cracked, broken and soaked with power-steering fluid like mine is?
If not, what's the part number and how much is Mr Nissan Dealer likely to charge me for one?
BTW: That's the undertray that catches stuff that gets dropped behing the radiator :-)
