Me again.
So I have two questions:
RobHowl ·
Just checked on accomodation near airfield, Travel Inn is only 11 miles away in Swindon and do double rooms for £41.95...
Beefeater is next door!
Thought I might cruise round area on Sunday!
Anyone else considering staying over?
