Garage or specialist in or near York
Have quite a lot that needs doing to my Z which is sadly off the road again (fortunately only because of no tax this time), and would like to find somewhere local to me - York. I've had some work done at the Nissan garage in Malton, and while they were very nice people, they won't do things non-nissan to the car and charge quite a bit. I've no longer got a driveway or garage and so can't do the larger jobs myself :(
Searched around quite a bit and not found anything other than the Nissan authorised place in Malton, so any recommendations would be greatly appreciated :)
i think C&S Woods are in th north east, meant to be very good, dnt have any details but am sure sum1 will post em up
There is no one in the North East,C&S are in the North West.
oh yeh NW! wot th hel am i on bout, got my rights n lefts confused
What do you need doing?
regards Kevin
In no particular order :) ;
Replacement NS turbo fitted (may possibly use this chance to upgrade turbos)
New speed sensor
Cambelt change
Compression test
Front discs change (although shouldn't have a problem doing this one myself)
Fuel lines replacement + upgrade, think I may have a small leak
AC recharge (has R12 in atm, not working)
Look at / sort out rear OS suspension
There's more, as with above budget allowing.
I've always worked on my cars myself before, but this is my first one with so many toys, and the current lack of decent work area is seriously inhibiting learning :'(
Not sure on the rest of the work, but a friend of mine up that way had the a/c in his old Pulsar done locally.. I'll see if I can find out where :)
I'm in Harrogate and have done all those jobs recently if you need any advice.
:x: :D
Cheers. Will give you a shout if needed :)
If your in Harrogate why does it say bloody Leeds in you signature or are you not sure where you are
Right-o Hatstand, I had a word with my friend up in York, and he had his a/c regassed at the Honda dealership locally - DeVries Honda (not that he was driving a Honda :))
But, his usual garage now has all the a/c gear, so he'd recommend there (they also service his Subaru Legacy GT-B and Renault 5 GT Turbo, and used to service his GTI-R), which is Neil at NS Motors on Clifton Moor.
HTH a bit :)
Aaron
Excellent cheers mate, i'll give them a call tomorrow...course once it's done it's not going to be hot anymore !
