speed sensor probs
fitted a new speed sensor the other day and i still got intermitent speedo
and power steering problems.
has anyone got a decent diagram of the whole circuit as i'm getting annoyed with it now.
also now my engine has started running eratically at low throttle any ideas
Import or UK model? Chances are its an import and the speedo convertor has gone tits up. Remove the gauge cluster cover (2 philips head screws) and look in there for a 'patched in' box. Remove this and reconnect the original wires where the convertor has been insterted and try that :)
yeh its an import n/a auto.but there's no speedo conversion on the car i can convert it in my head easily enough.
even taken off connectors to sensor and soldered the joints.
need to find entire route and what it passes through
First port of call is the speedo. It then goes off to the other control units after that...
i need a link to a circuit diagram if someone has one i can work out the rest myself.
first stop after sensor is speedo?
