Turbo on/off switch?
I've heard you can hook up a system that allows you to switch your turbs on and off....anyone knw of this and how much it costs / where to get one??
Cheers,
DAN :cool:
Switching the turbo`s OFF is not exactly possible as they are driven by the exhaust gas and unless you had a system that stopped that your only method is of controlling boost via the waste gates, keeping them permanently open would leave you with no boost but quite how you would do that successfully?
You could wire a supplementary circuit in to the stock boost controllers ( safety boost) and reduce boost to that of safety boost ( or cold running) approx. psi for say wet weather driving.
Jeff TT
Oops last line should read: approx. 5psi for say wet weather driving.
Jeff TT
