Quick tip for guys with auto boxes that may seem to have lost there sparkle on kick down or seem to be a bit reluctant to select a lower gear when exiting an island around town etc.
The kick down and the lower gear selection is operated by a micro switch on the accelerator, the plate that activates this is very thin and easily bent, it seems of late I have come across many zeds with this plate bent down too low often as a result of cables from alarms etc. getting caught up between the two or if the drivers foot slips too high up the pedal.
The result is the kick down switch is only activated when the accelerator is mashed in to the carpet or in a couple of case not at all, takes two minutes with a torch to reposition (bend) it back in to place, in fact with a bit of testing you can pull it up slightly higher than normal which will give a quicker response around town.
Auto box kick downs,
Jeff TT
