protoj ·
Come on, you're round here somewhere geeZer!
Was it you who sent me "Awight" on me mobile dog & bone at some point over the weekend mate?
Since Stripe(male Rottie) ate my shitty B.T. Crapnet mobile I've lost your number mate! Doh! So it doesn't say Mat Lad calling anymore.
Drop me your number in a mail matey!
