August 24, 200422 yr I have instructions from TT Net but I am not sure if these will be any good as they are written for LHD. Anyone fitted a Boost gauge recently?, if so any tips?. Cheers.
August 24, 200422 yr I have instructions from TT Net but I am not sure if these will be any good as they are written for LHD. Anyone fitted a Boost gauge recently?, if so any tips?. Cheers. Kia are you putting in a pod ?? the best place to thread the hose through is along side the bonnet open release , use a coat hanger with the hose taped on to it you will then go through the grommet quite easily then just tee it off the balance bar (drivers side)
August 24, 200422 yr Ryan Yes I have a A-Pillar pod so what you have suggested sounds as if it will work fine. Thanks.
August 24, 200422 yr Ryan Yes I have a A-Pillar pod so what you have suggested sounds as if it will work fine. Thanks. lol just make sure you thread it down the hole where the old A pillar used to be first , you will see what I mean when you remove it
Cheers.
