Wierd Noise
Help please
Just recently my 91 Jap import has developed this strange noise. It sound like it could be a electric fan bearing grumble coming from the far right hand side of the cab, under the dashboard and behind the guages. It only starts after a few minutes, seems not connected to motor speed and is not affected by the fan settings. IS there anything mechanical there? It sounds like a loose or worn bearing, but isn't very loud or worrying.
Ta Chris Davies
:confused: :confused:
Not much help mate but my Alfa does this too, only from the passenger side. Mechanic reckons it's something to do with the heating system/air con.
Are you sure it isnt the little fan for the aircon sensor in the section between the t tops. That often dries out and gets noisy.
Willie
I don't know what this fan is or even where it is. More info if possible
It's a good job I don't make my living as a mechanic!!
Chris
Chris
Basically the gizmo on the roof- with the two map lights - it has a bit in it with slots for airflow. If you take it down - cant remember if its clips or screws - you can see the little fan. Clean away all the fluff and stuff and a tiny blob of 3 in 1 oil onto the bushes of the fan will normally shut it up. I think if its noisy it stops when you switch the aircon to off - obviously this fan stops too. It is there to waft cabin air across a temp sensor in order to tell the aircon how its doing! Mines made noises years ago but has been fine since I lubed it.
