Lightened pulley fan belts
I got a lightened pulley from the US a while back which came with a set of fan belts, but they are all too short. DOes any one know which length fan belts I need to use with my lightened pulley?
Stuart
Stu, depending on if your a jap spec or UK spec but only one is different, it should be A/C A192M-42LSAVW, ALT A195M-97EOMUW ,P/S 11950-32F10
Gates belts are also easily available from your local motor factors, do a search on TT.net and it will bring the gates numbers up.
Strange to be too short mate, if anything i would expect too long with only one belt too short if your a UK model.
cheers
smithy
Easiest way stu is to just wrap a piece of string around it to the correct length, and then get the get the right amount of valleys/peaks on your belt.
