Removing black exterior strip middle of targa
How do I do this? I want to replace it.
Hi Mate
I replaced this with a new one from Nissan - £68. Really makes a difference as the old one had flaked away to nothing and looked crap.
If I remember rightly it was just a couple of nuts and bolts on either side but you had to remove the interior trim to do it. Not difficult though.
Mark
you have to drop the roof lining then there is 8 x 10mm nuts to remove and pull it up, mine had some sealant under it so took a bit of gentle tugging and it was off, took about an hour to do, not hard at all.
Mark
Thanks Mark & Suffolk.
Mark, do you have the part number for the Nissan part still?
Mooch
  • 1 year later...
How do I drop the roof lining? Do I have to remove all the pillar panels etc.?
Mooch, take a look at THIS LINK , it'll show you everything you need regarding the strips, also includes the part numbers.
Dave
EDIT** :headvswal :headvswal Didn't notice the date of the original post!
Thanks anyway Dave. Still need to know how to drop the roof lining. Cheers to anyone who can help. Mooch.
bttt
Thanks for all replies. Know what I'm doing now.
Dave - I've been through your guide pages twice and still see no mention of the centre targa strip. This is the plastic strip that runs down the centre of the vehicle between the T-Tops.
Anyway, I've got the picture now. It seems I may need to drop the roof lining but only locally, from ABOVE, to get at the bottom of the retainer bolts. I won't need to take the whole lining off from inside.
