Brake pipe fitting sizes
Anyone know the size & thread of the brake hard line fittings off the top of their head? Want to get some Tee pieces so I can junk the ABS.
I should know this as I snapped my hard brake line last year and had to make up a new set myself........erm......leave it with me! I will find out. Still got the old bits in my tool box.
It's heavy and doesn't work with bigger callipars very well. And I'm a bit of a purist.
You might find that the MOT testers won't accept it. Ran the idea past my mechanic and he says don't do it.
How would an MOT test determine if the ABS had been removed? Assuming you take the warning bulb out lol
ย
Should lose a bit more weight John... is it true that you and Nelson are actually the same person, I mean - I've never seen you in the same room at the same time :eek:
ย
They SHOULD test the tell tale light, comes on with ignition, goes out when ABS unit does its stuff...still MOT testers arent always the sharpest...
.....and there's the small question of insurance. Better ask first if you must do it.
