Turbo question
I just got some T28's off a Skyline and am very anxious to put them on my z32. I was just wondering if anyone knows where I can get all the thing I will need to adapt them to my z and what they are. Thanks for the help.
Jimmy
You'll need to re-orientate the compressor and exhaust housings in relation to the centre housing. You'll then need to relocate the actuator bracket since this will no longer line up with the wastegate due to it being mounted on the compressor housing (you've just changed the positions of them). You'll then need some 5 bolt downpipes.
CheerZ,
Andy
thought they are t25 on a skyline i lot of work to fit ( mine are t25 ceramic roller bearing of a gtr34 ) but not fitted yet
Dont ceramic blades explode if pushed too hard?
yep
yep not good after one bar, but since that will be all i'll be running should be o.k. less boost higher compression
does anyone know where i could get the proper gaskets and which ones they are?
