Misfiring - B****RD!!!!
Just when I thought id sorted the problem out another one starts!
Driving along quite happily earlier on when it starts missing one or two cylinders. It's been doing it ever since - really lumpy at low revs, struggling up the scale, and then almost normal over say 4000.
The cars been burning rich recently on and off cos of my BOVs - would this cause a couple of the plugs to gradually carbon up?
if you suspect plugs,pull em out,then try swapping coil packs to see if it improves,also check the connectors for cr@p!-easy things first! :)
Wahey! - the damn PTU connector had worked its way loose :rofl: . Was firing on one cylinder in the end before a quick call to Jeff sorted it. Thanks mate!
lol, PTU and coilpacks are a ****er. I was contemplating an engine rebuild when I get me new tubbies done, thought id lost a couple of cylinders and worked out to be two coilpacks loose :rolleyes:
I'm surprised the damn thing moved at all - it was firing at a rate of three pops per second - followed by a loud BANG! :rofl: :slap: Certainly turned a few heads but for the wrong reasons :(
Once again thanks to Jeff for an instant over-the-phone solution :bow:
