protoj · 17 hours ago 17 hr
Returning from KFC tonight having returned my
order because they got it wrong again!
Just about to pass a BMW 328i on the dual
carriageway and he speeds up,I drop down to
third, floor it and blast him into my rear
view mirror.
Traffic lights are on red, stop side by side
revving for the launch, one light, two lights
Three lights GO GO GO GO,I kill him in 1st, lose him in 2nd,totally lost him in 3rd, brake hard for next set of lights, BMW eventually arrives, sit there laughing
and grinning at each other, i cannot believe the bastard wants more!
The lights changed to green and i did it all
over again, wouldn`t mind but i was supposed
to turn left at the first set of lights to
go home, just couldn`t miss the fun!
Ian
