Replacing plenum - can I use standard water hosing?
Hi
As title really :)
Is there a need to use expensive Nissan water hoses when replacing the ones under the plenum or can I just cut the length from a roll?
I'm wondering if there are any sharp bends I guess where universal hosing would kink, or if there are any pieces with different diameters on each end.
Thanks :cool:
Pete
if you are talking about doin the water bypass mate, just standard hosing will do the trick, if replacing the one sunder the plenum.....I sdont know :(
Dont know about the water ones, but I know the breather ones on bottom of tb's have reducers in with wire brushes, they will prolly need replacing if brittle, and the PCV hoses are the same, they have reducers in. (but you prolly knew that anyways ;))
I would imagine the water ones are just normal tho?
Que duff or paul c lol
Hi
As title really :)
Thanks :cool:
Pete
Pete as Hugh has said would be much easier to just do the bypass ,(with normal water hose) (and thats car water hose not garden hose Pete :xxx: ) but if you want to replace all the little hoses then I have a spare set that I did not use because i did the bypass , more than welcome to them mate :)
Yeah I did the pcvs a few months back so I guess they will be fine cheers
Arent there a load of small water hoses dotted around underneath? Can I replace those with standard hosing?
Pete
Ahh cheers Ryan, so they bypass replaces all those hoses? I seeeeeee, nice one I'll just do that then :)
Spot on bud
I have a full set of plenum water hoses too if anyone is wants them for a few squids.
Ill have em chris please how much do you want for em??
