No Power?
Hi all I need Help!!!
My Zed will not pull away it just bogs badly,if you rev it theres a noticable flat spot then it picks up..
It idles perfectly until you try to pull away then in just bogs and trys to cut out.and sometime does.
it starts first time every time but is powerless......
I thought it was the AFM but when you disconnect it the ZED cuts out.
i thought it may be the throttle position sensor as it only cuts out if you disconnect the bottom connector, but still runs with no change if you leave the bottom connector connected but disconnect only the main connector which fits to the main body of the TPS....
Any Help Please !!!!
i am only getting a Code 34 which i know is the det sensor but the car should still drive ok but on saftey boost.... :cry:
The car wont start / go at all without an afm.
If the AFM is faulty then it goes into a safety mode which means usualy you cant go over 3000 rpm and it sounds rough as a bag of nails.
You should really check the PTU connectors on both sides and the coil packs (im gettin dejavu third time I said this to someone this week lol)
I have cleaned both sides of PTU and tried another its not missing Either it runs smooth as usual just goes flat dead when you try to rev it which im thinking points to a TPS or AFM but i would like help from anyone who has had same symtoms or simular ...
Remember its not missing it runs fine but it has a flat spot and it seems to be clicking during the flat spot near the idle soleniod and it has no power but if i hold the throttle open long enough it will enventuly go over 3000rpm to as much as i like but you have to go past the flat spot first but you cant drive it you put your foot to the floor and nothing just dies
i had same prob, has you`re AFM cracked round the top, mine was letting in water/damp therefore rotting the inside of the AFM and the car kept on cutting out everytime i tried to put my foot down, sometimes not starting again for a day, got mine all cleaned inside and dried out, siliconed round the cracks and it has been fine, bought another one anyway so i have a spare...interested???
you wont be able to send him pm's he's got to subscribe first!
