no codes other than 55, hesitation from idle to part throttle, while crusing fine occasional cut out when idling.
Hesitation on acceleration.?? :bow:
Whats the idle like? Have you checked all the connectors (injector/coil pack/tempsender)? Have you cleaned out the throttle bodies? Could be a PTU faliure. Loadsa other stuff as well mate. Let us know.
Ivan
Start with the easy stuff first. Try cleaning the throttle bodies. Also clean the idle valve assembly at the rear passenger side of the upper intake.
i just happen to have an air flow meter for sale, it`s in good working order (been repaired) also i`ve siliconed round it, casing was cracked along the top letting in damp and water corroding the terminals,it is now fine will let it go for £50 intrested?
tried to PM you mate but no luck please call me on 07951246602 if you want to do a deal
