problems problems
well, thought I would have a weekend of attaching bits!! fitted new apexi intake (Thanks to Chris@getgreddy;)) front strut brace (Thanks to Danny) and new hks dump valves complete with hard pipes (Cheers Ryan) well have fitted the d/v's as instructed, made sure all t pieces were secured with teeny tiny jubi clips so as airtight as poss (after idling problem discussed with Ryan) checked and double checked the clips onto the intakes themselves.
now apart from needing to remove/cap off the factory recircs why should it do the following:
1.if shifted into park or Neutral it cannot settle at a steady idle goes from almost nothing to about 11/1200 then eventually cuts out. however if at a standstill you leave it in Drive... idles at about 7-800 no problem.
2. if you drive hard then have to come to a complete stop, the revs dip and it can cut out (PITA at roundabouts!!)
3. noticed when then engine was struggling to idle the centre section of the d/vs was slowly pulsing in and out, if I press the centre to stop it moving, the revs pick up and the car idles perfect.
help pls? nearly got shat on by a rover on the way home its that chronic a problem!!!!!!!!!
but seriously folks any ideas????
Mucho Thankios in advance
Speedy :(
Speedy :(
Sounds like air getting sucked in from somewhere...the root of all evil..
A rover eh...how embarrasing..
Did you have dark glasses on?
Are The Dvs Adjustable,if So Sounds Like U Need To Wind Em In A Bit To Stop The Flutter-just A Thought :)
No idea matey they are hks but not ssqv they are fairly large with a trumpet shape on the end !!!!
Hmmm,no Idea,but If There's An Allen Screw In The Top With A Locknut It Means U Can Adjust It.
no they are not adjustable , are you sure you teed them all correctly Liam ??
yep drivers side one pipe runs over to passenger side - teed in to other d/v then spare side of that t running into the pipe that runs from the lowest hex head bolt on the passenger side of plenum. all t's connected with clips.
strange that if i push the end of the valve in, she ticks over as norm..
on the upside when she is going she is running well!! makes it even more frustrating
Liam there are two silver screws in the black cap try removing these, I will check the spare tubbing I had to make sure that its teed of the right point in the engine vac
Surely these are adjustable?! Most DV's are...
They shouldn't be opening on idle.
removed the screws... still doing it!!! its the passenger side. You can hear the air escaping through the trumpet as it is ticking over - does this mean its no good? or maybe there are internals that are worn???????
Liam there should not be air escaping :confused: they were fine on my car before i rebuilt it and took them off 6 weeks ago , like I say will ring you at lunchtime , more than happy to give your money back if they are knackered mate
Ryan
If they are similar to the TurboXS ones I have, you might be able to put a spacer washer under the spring to increase the pressure?
Chris they are a sealed unit
Did you tell me you got em sorted todat Liam ??? Were they Teeeeed off the wrong pipes ???
Aye !!!
