Hi All
i need to inspect the C.A.S connector and need to know how to remove as i have removed the 3-10mm bolts and marked previous position but Mine seems to be jammed....i cant turn it either way or pull it out??? is this common they are supposed to be able to be removed or replaced surely....??
Any ideas? :confused:
Hmm, give it a wiggle mate it should come out eventually.
Have a read of the manual under section EF/EC page 70 ish.
They do sometimes jam, I know mine is! However you don't need to remove it to check the connectot - OTT ;) Do it in situ :)
