Me again.
So I have two questions:
RobHowl ·
All,
I think my clutch is on its last legs,
bits high up the pedal travel and sometimes engages with a 'clonk' in lower gears.
Not slipping at all though, I assuming its worn.
It's due a service next month so I'll get the spanner monkeys to check the master/slave cylinders for leaks, fluid levels ok though.
Anyways, Mandela has quoted me just under £400 to supply and fit (inc VAT) for a standard unit.
Are aftermarket units cheaper/better?
I'm not looking at Stage69 tuning, maybe just inlet/exhaust upgrade early next year, so will the stock unit be up to that?
Glenn
