Help ! Only just got the Zed and i have a light tha keeps coming on the dash, it looks like maybe a section of exhaust with lines going upwads coming off it ?
bit stuck as to what it is ? any ideas anyone ?
Your cats are overheating.........
Do a search and you'll get the info you need. :)
Matty.
your pussey is on fire
thanks guys, stupid question for you, how do i stop it overheating ? or do they need replacing ?
it may mean you are getting detonation
Try a search !
However, it's quite likely that you have a failing/loose coilpack connector. No spark = unburnt fuel blown down the exhaust to the hot cats whereupon it catches fire and the temp sensor light comes on !
possibly unburnt fuel going in the cats and igniting in there , have your air filters checked they may be clogged making the fuel very Rich ..or have the mixture set up properly
