uneven idle problem cured (i think!)
i know a few of you have posted about high idle/surging so i thought id post my findings.
had done all the usual several times ( clean TB's, reset then replaced TPS, cleaned then replaced engine temp sensor & harness etc), but still had an idle that would suddenly jump up to 1500rpm.
took the plunge & removed & cleaned out the idle control valve.
it was a bit of a git to remove as its quite tight at the back of the plenum (pass side). not too bad but if your gonna take it of get a new gasket first. mine broke up & i had to make a new one!!
once it was off i could see the electrical contacts were very corroded, i think this was prob most of the problem with mine, cleaned them up.
while it was off i also stripped it down, quite a bit of carbon deposits in there. (again take care if doing this, theres small springs & plungers in there ;)) cleaned them all up with carb cleaner and a little wet & dry on the plungers.
put it all back together & the idles spot on now :)
if it stays like this i'll be a happy bunny :D
Am planning to have the plenum off mine this weekend, may try this, along with the water by-pass and the pcv valves. I know you can do all that with the plenum on, but I am a lazy sod :)
